What's next?
Old Feb 26, 2013 | 05:31 PM
Hrdtyme's Avatar
Default What's next?
i just got my new rims and tires this week along with 4 inch springs. The lift i have consist of springs, rear traction bar bracket, sway bar links, brake line ex brackets and bump stops. I took it off road last weekend and so far everything works fine. I noticed on the freeway it swerved a little on uneven surface or lines but other than that it was ok. Should i get gussets, sleeves, lower front control arms? Any advice will help but what would be the most important thing i should buy next is the question.
Thanks
Old Feb 26, 2013 | 05:45 PM
Jersey_Devil's Avatar
What size tires did u go with? If ur 35" or bigger yes on the gussets and sleeves/truss work, adjustable front track bar ur gonna need, I don't think u said u had one.... What kind of wheelin u do? Rocks, mud or both? All sorts of things to consider before buying stuff... Maybe u want bumpers, sliders, winch...
Got any pics?
Sent from my Samsung Galaxy Tab 10.1 using Tapatalk 2
Old Feb 26, 2013 | 05:47 PM
Staytru06's Avatar
At the least I would recommend front and rear lower control arms to help get the tire back to stock location, fix your castor..sounds like you got a good set up tho.
Old Feb 26, 2013 | 05:50 PM
catahoula's Avatar
You might want to add driveshafts to the list for future replacement as well.
Old Feb 26, 2013 | 06:16 PM
Smashboogie 4x4's Avatar
Former Vendor
Definitely go with a set of adjustable lower control arms. We would recommend the Rock Krawler arms.
Rock Krawler Control Arms | Facebook
PM us if you would like a quote.
Old Feb 26, 2013 | 06:34 PM
cis911's Avatar
Thanks
Did your lift come With an adjustable front track bar? If not I would def get one then adjustable front lower control arms then rear adjustable control arms.
Old Feb 26, 2013 | 06:40 PM
enash965's Avatar
Mine did the same thing with my 3" lift and 35s. Now I am ordering front lower and rear upper control arms and front and rear adjustable track bars to help because if I go faster than 55 on the highway it sways a lot.
Old Feb 26, 2013 | 07:36 PM
Hrdtyme's Avatar
Got any pics?
I have 35 inch wild peaks with 17x9 inch eagle wheels
Old Feb 26, 2013 | 07:38 PM
Hrdtyme's Avatar
Thanks for the info. i will post pics when i learn how, lol
Old Feb 26, 2013 | 07:39 PM
Hrdtyme's Avatar
Thank you.
