whats the point?
http://www.quadratec.com/products/12203_100_07.htm
sint the reason we buy swing away tire carriers is so we dont break the door how does this change it if its still on the door
http://www.quadratec.com/products/12226_201_07_T.htm
can this be used with any bumper?
http://www.quadratec.com/products/12211_00_07.htm
can that be used with any bumper?
The first one allows you to fit a larger tire on the gate.
The second works with the Tera bumper http://www.quadratec.com/products/12226_200_07_T.htm
The third works with the Mopar Off road bumper http://www.quadratec.com/products/12118_10_07.htm
but why would u want to fit a larger tire on the gate doesnt it put more stress on it an d cause it to break or was that the little plastic carrier that breaks
so theres no possible way for those to be used with other bumpers
cuz for the price id rather do that that way later on i can get a diff bumper i like the ranchos price but its got no looks ya know
Check out this thread from another member if your thinking of getting the Rancho
https://www.jk-forum.com/forums/show...ghlight=rancho
I ran the besttop one for about 2 years along with a 35" Toyo (heavy), and did not notice any issues with the gate. I attribute this to the fact that the weight is better dispersed across the gate, and the vertical bars keep the tire from rocking back and forth which would prematurely wear on the hinges and latch. You are still leaving the weight of the tire on the gate, but it is tight against the gate and doesn't create the leverage that other mounting plates do. It probably is still not the best way to mount a 35", but again, I didn't have any problems. Once I upgraded to 37's, it wouldn't get the tire high enough, so I switched to a different bumper and tire carrier.
