Wheel adapters
Old Jan 22, 2015 | 06:00 AM
andore's Avatar
Default Wheel adapters
Hey guys thought I would just pick your brains as I was doing a little reading but not coming up with a definite answer. I am currently running 5x5-5x5.5 wheel adapters. The person I got my wheels from gave me his adapters so I am not sure if they're hubcentric or not. But is it possible that if they are not they could help contribute to initiating death wobble? I feel like that's definitely an instance that could create a shake and lead to DW. I have replaced everything in my front end and currently having my wheels balanced. The only thing that I would have left that's not brand new is the steering linkage itself which im looking into getting a sector shaft brace and the upper control arms are stock.
Old Jan 22, 2015 | 06:22 AM
Rob 12B1P's Avatar
Pretty easy to check and see if the spacer is centric. Just pull the lug nuts holding the spacer on and see if the spacer is riding on the machined lip or loose. My guess is that it should be.
Old Jan 22, 2015 | 06:30 AM
tribulation138's Avatar
Ive had non HC adapters b4 with no spacer ring. The wobble was contant all the time. I bought plastic spacer rings to center the adapters. What a difference. I now have aftermarket rims and glad i kept the rings cause i needed them again.
Imo alot of people overlook this problem with after market rims
Old Jan 22, 2015 | 11:26 AM
andore's Avatar
They're not hubcentric i just took a look. the shake isnt constant though im getting its at certain speeds. however i still think hubcentric would probably be a good way to go.
Old Jan 22, 2015 | 02:22 PM
Yes it would
Old Jan 23, 2015 | 07:32 AM
andore's Avatar
Out of curiosity where did you find the rings? I just looked into them quickly and that seems like a decent way to do it as well plus they're cheap if it doesnt work.
Old Jan 23, 2015 | 12:18 PM
Ill have to try to remember. I remember they shipped from cali
Old Jan 24, 2015 | 12:53 PM
http://www.bigbrandwheels.com/Hub-Ce...ings-Dept/263/
