Wheel Adapters & Wheel Options ...
Hey all,
so i am trying to narrow down to a few wheels that I would be interested in getting.
My fave so far is the pro comp 7289/8089..... with just one hitch... they dont come in the right bolt pattern in the 20" wheel... only in the 18" wheel. I was thinking of doing 20" wheels with a 37" tire....
here is the wheel i am interested in:
offroadunlimited.com/orustore/pc/viewPrd.asp?idcategory=921&idproduct=9011
^^^^ What im wondering is it even physically possible to get an adapter to mount a "6 on 5.5" bolt patter to our JK's which are 5 on 5. I presume its impossible because it requires an extra bolt.... but thought I would ask to make sure anyways?
If not I guess I could look at another wheel or settle for the 18's.
Also I just realized after making this post that a 5x135mm version or 5x5.5 version is also available... anyway to make those work?
Input appreciated.
Thanks all!!!
Input appreciated.
Thanks all!!!
Last edited by HappyCurmudgeon; Dec 30, 2010 at 10:38 AM. Reason: removed non sponsor hyperlink.
5x5 to 5x5.5 adapters are available and used quite often. (front hub conversion kits change to this pattern). I have not seen any that would let you go to a 6 bolt pattern.
thanks a bunch again!!!!
