Wheel Centered - Stability Ctrl still coming on...
Old May 4, 2009 | 01:44 PM
dgore2's Avatar
Default Wheel Centered - Stability Ctrl still coming on...
I installed my OME lift on Saturday. All is well with the install, but the stability control keeps kicking in...like many others...on right hand sweeping turns and sometimes on left hand turns. I've centered the steering wheel about 10 times now and when driving it, it seems to be spot on. When I installed the lift, I put on FT adjustable track bars front and rear. The front axle is centered, but the rear is out about a 1/2" to the passenger side. Could that be my problem? I'm thinking that might be enough that when turning to the right, the right side wheels are not turning at exactly the same speed. Of course, the same would be true of the left, just in the opposite order??? The only other thing I can think of is the sway bar links. I didn't replace them, and of course they are at pretty dramatic downward angles? Don't know if that might be putting some undue pressure on the axles or pulling them one way or the other??? Of course it could be that I haven't had the computer flashed for the 33" tires, but I had them on for a day before the lift and didn't have this problem.
Any ideas would help.
