Wheel Offset Stress?
Old Feb 13, 2009 | 07:24 AM
Hellbound13's Avatar
Default Wheel Offset Stress?
Do wheel with a more negative offset put more stress on suspension components?
i.e. "deep dish" style prcomp rims and such?
Old Feb 13, 2009 | 07:28 AM
bly109's Avatar
Yes, the less backspacing a wheel has, the more leaverage it has to put stress on components such as ball joints and wheel bearing.
Old Feb 13, 2009 | 10:32 AM
08RUBIJK's Avatar
This also put more stress (leverage) on your axle tubes and knuckle C's, which are already a weak point on the JK.
Old Feb 13, 2009 | 10:49 AM
Calypso's Avatar
I think you are pretty safe not exceeding the max backspacing is 4- 4.5.
Old Feb 13, 2009 | 09:26 PM
I am wondering because since installing pro comp rims that I believe have a 4.5 backspacing and different offset, I have had balljoints, drag link and tie road all go. They were installed at 6K and I now have 15K. Also my ride is somewhat rough and I can feel all the little dips, bumps and road kick back in the steering wheel and gas pedal.
Old Feb 13, 2009 | 09:38 PM
mkjeep's Avatar
Hellbound, your jk is mad at you for not modding the suspension. I bet that is where your problem is. GO EVO, that's what I'm saving for at the moment.
Old Feb 13, 2009 | 09:41 PM
mkjeep's Avatar
Also , I'm running 4.5 bs with 1.5 wheel spacers. Equals 3.0 backspace, balls are hangin in there.
Old Feb 14, 2009 | 05:13 AM
Yeah but you are also not running the stock suspension, right?
I can't believe the stock suspension is so weak that it can't even handle a different offset wheels..
Old Feb 14, 2009 | 09:30 AM
mkjeep's Avatar
Right, but I don't think it would make much of a measurable difference since I'm running 35's also. I could be wrong, but I don't think different springs and shocks are gonna change anything with the ball joints. 2 exact rigs , one different springs and shocks, but same tires and backspacing, can't see where that would affect the ball joints much at all.
Old Feb 14, 2009 | 07:02 PM
Actually I am running the silent armors. Do you think an adjustable trackbar would help reduce the rough ride a road kick back I am getting?
