Wheel Question
I installed a AEV 2.5 lift and Geo brackets. I am putting on 12.50x35x17s. The MHT fuel Wheels come in two back spaces. 4.5 or 5. Which should I choose? I don't want the rims sticking out of the fender.
Like many others, on this forum, will tell you. Go do some research. Lots of threads on wheels, backspacing, lifts, etc. and I would bet that if you searched hard enough you'd find someone talking about both set ups, and maybe even some pictures.
The FAQ's at the top of this modified area ndicate that a 4.5" backspace will be good for a 35x12.50 tire.
The Thoughts On Lifts at the top of this modified area indicate that a 4.5" backspace will be good for a 35x12.50 tire.
In the recommendations area of each particular lift, many lift mfg's will indicate that a 4.5" backspace will be good for a 35x12.50 tire.
So, I think that you might be safe with a 4.5" backspace for your 35x12.50 tires.
