Wheel ?'s
After reviewing my order I found out that the "c" upgrade option available on the X comes with those HORRIBLE looking stock rims. Needless to say thats going to be the first thing I upgrade. But I had a couple questions.
the 5 on 5 lug pattern... I know the first 5 is the number of lugs, but was curious as the the second 5. Im guessing that its with width of the bolts but not sure. 5mm??
What about bead lock rims? Whats the major purpose of these? Is it just ease of being able to fit a new tire on it yourself?
Backspacing... Whats the number and how is it measured? I think its from the fitting part on the rim and to the inside wall (if the wheel were laying flat on the ground) Is it in cm's? and what is the standard backspacing?
also rim width... What would the best width be? What width would I be able to find the widest variety of tires to fit it (namely Interco's)
Rim size... What would be the best size in yall's opinion to go with? The standard 15? or 16, 17in rims? Or is it a mear looks thing...
Sorry about all the questions here. Hopefully yall can give me somewhat of a clearer picture of what I'd want in new wheels.
Thanks!
Thanks!
Hope that helps you out a bit. Let me know if you have any other questions.
If I intend on getting a 3" Lift for my 4-door JK Rubicon, will this allow for 35" tires? Can I go any bigger without rubbing? What would be the best wheel size to include backspacing? Will I be forced to put on new flares?
Someone should invent a tire/wheel size calculator for jeeps.
If you ordered a JK RUBI. then it comes with 17" wheels.
I myself am looking for wheels to fit my 35"'s.
I thought that Spidertrax wheel spacers would take care of the stock backspacing issues and prevent the tires from rubbing on the suspension components.
Am I wrong to assume this will work?????
Regarding the best wheel size to go with, I think a 17x8 ought to do well with this set up but I'm not 100% sure what backspacing to go with yet. On the TJ's with their 5.5" of BS, the widest tire you could safely run was 10.50 as anything wider would have resulted in the rear tire sidewalls rubbing the upper spring perch. This may be different on the JK and you might even be able to get away with more but I won't know for sure until I've had a chance to give it another look and take some measurements.
As far as needing new flares go, that all depends on how wide of a tire you can run on stock BS.
IF there are any rubbing issues, yes, a set of wheel spacers should push out your wheels enough to allow you to run wider tires.
