Wheel Spacer Help
Old Jul 12, 2013 | 08:16 PM
CommandoJeep12's Avatar
Default Wheel Spacer Help
I am very confused and would appreciate some help. I have a 2013 sport s. I heard that 1.25 inch wheel spacers will need cutting/trimming modifications to the factory studs but 1.5 inch clear it enough.
BTW- ill be running 315/70/17 hankook mt, on pro comp 7069 with 4.75 inch backspacing.
Old Jul 12, 2013 | 08:23 PM
k0260's Avatar
You shouldn't need spacers if using the pro-comp wheels you mentioned. Also, I'm running the Hankook's 315/70/17's, nice tires
Old Jul 12, 2013 | 09:10 PM
karls's Avatar
There should never be any reason to trim the factory studs.....put down the sawzall.
Sent from my DROID4 using Tapatalk 4 Beta
Old Jul 12, 2013 | 09:16 PM
boopiejones's Avatar
i'm running that exact same wheel with the same backspacing and the same size (but different brand) of tire. no spacers and it looks great and doesn't rub with a 2.5 inch lift...
Old Jul 12, 2013 | 09:25 PM
Chemlight's Avatar
Yup. Sawzall equals bad. Ha. You should not need a spaced. I do, however; due to back spacing issues on stock wheels. I run stock rubi wheels and spidertrax 1.5" spacers and 315/70/17 nitto trails. No rubbing
Old Jul 14, 2013 | 01:23 PM
thanks for the help! i just read on some forums about guys who had to trim the stud which i thought was a bit crazy. I am only gunna have a two inch lift but ill have cut fenders, i think i should be okay.
