Wheel spacer problems
Old Jun 12, 2011 | 08:24 AM
Dirty Dog's Avatar
Default Wheel spacer problems
I put some new wheel spacers on my jeep and was getting a wobble. When I took them off no wobble. This was coming from the front end. Any ideas?????
Old Jun 12, 2011 | 08:46 AM
Shadow's_Jeep's Avatar
If you have after market wheels they should right back spacing (Black Pro Comp Extreme 17x9). Why would you need wheel spacers ?
Old Jun 12, 2011 | 08:53 AM
Battlefrog's Avatar
Did you torque them down to specs, drive them for 50 or so miles and torque them down again ? Also, did you torque the wheel lugs to specs?
Old Jun 12, 2011 | 08:55 AM
Battlefrog's Avatar
If you need a torque wrench let me know. I believe your pretty close to me. I'm by the airport in Newport news. I'm running spacers and could come take a look at them as well....
Old Jun 12, 2011 | 09:11 AM
daspes's Avatar
x2
x2
x2, except I'm in Portsmouth.
Old Jun 12, 2011 | 09:12 AM
Battlefrog's Avatar
Originally Posted by daspes
x2
x2
How far is that from Newport news, roughly?
Old Jun 12, 2011 | 09:17 AM
Battlefrog's Avatar
Also, did you remove the retainer clips off the wheel studs ?
Old Jun 12, 2011 | 09:24 AM
JKU Rubicon's Avatar
Eddie wrote:
If this is the very first time you’ve pulled off your Jeep JK Wrangler’s wheels, you will find a set of assembly washers attached to the wheel studs securing the rotor onto the axle. Use a small flathead screwdriver or needlenose pliers to pull up the tabs in the center of the washers.
YOU HAVE TO REMOVE THEM BEFORE INSTALLING THE SPACERS
Old Jun 12, 2011 | 09:34 AM
daspes's Avatar
I'm in the Churchland Area. Straight across the Monitor-Meremac frm NN, about 2 miles from where the 664 hits the 164.
Old Jun 12, 2011 | 09:43 AM
Battlefrog's Avatar
Good to know lol.... Asked the wrong person hahaha...
