wheel spacers
Old Aug 11, 2013 | 05:30 AM
redleg13fa's Avatar
Default wheel spacers
How do I know if I'm gonna need wheel spacers. Looking to upgrade to steel wheels and 35x12.5x17 tires. I have 2011 Rubicon unlimited with 3.5 RC lift. Right now factory tires (255x70x17) and factory wheels. Just need to know if I need spacers before I purchase tires and wheels.
Old Aug 11, 2013 | 06:06 AM
Gman*2007's Avatar
If you purchase wheels with 4.5" back spacing you will not need spacers. The factory wheels are about 6", then you'll need 1.5" spacers.
Old Aug 11, 2013 | 07:17 AM
Ryan0260's Avatar
The only reason you would want to run a spacer is if you run an oversized tire on the factory wheel. Otherwise, find a wheel with the proper backspacing, as mentioned.
Old Aug 11, 2013 | 07:29 AM
redleg13fa's Avatar
Thanks for the info. Is discount tire pretty knowledgeable on that?
Old Aug 11, 2013 | 07:33 AM
JK Inspired's Avatar
Factory wheel BS is 6.25 and a set of 1.25 spacers will fit 12.5 wide tires.
Old Aug 11, 2013 | 08:02 AM
JE8154's Avatar
On road 4.5" back spacing should be enough. offroad aired down at full lock you might still rub in some spots. I was rubbing on my sway bar at full lock with 315/75/16's with 4.5" back spacing. Just added a 1.5" spacer last night. You could always adjust your steering stops to fix this as well
