Wheel spacers for 33's ???
Old Apr 15, 2009 | 12:03 PM
cgtweet's Avatar
Default Wheel spacers for 33's ???
I have decided to go with Hankook 285/70/17 (33 inch) tires on stock Rubi wheels. I currently have a OME HD lift on my 2 dr. Will I need wheel spacers? If so, what size? 1.25? 1.5?
Thanks,
Vince
Old Apr 15, 2009 | 12:07 PM
priell3's Avatar
Q: What is the biggest size tire I can fit on my stock Jeep JK Wrangler?
A: The largest tire size that the factory recommends is a 255/75R17 (which comes standard on Rubicon models) or a 32x10.50. However, there are many Jeep JK Wrangler owners who are currently running as big as 285/70R17 or 33x10.50's with little to no rubbing issues.
Q: What is the biggest size tire that I can I fit with a 2.5" Budget Boost?
A: 33" without any problems and 35" tires with only minor rubbing at a full flex. Depending on how wide your tires are, you may experience some rubbing at a full turn especially if you did not install an adjustable front track bar and/or are still running factory wheels which have 6.25" of back spacing.
Old Apr 15, 2009 | 12:11 PM
BMPJDS's Avatar
you can run the tires fine without spacers. some people do however have very minor rubbing at full turn.
Old Apr 15, 2009 | 12:13 PM
cgtweet's Avatar
Default re
Thanks a bunch for the quick replies. Appreciate it.
Vince
Old Apr 15, 2009 | 12:28 PM
Finn's Avatar
I have 285/70/17 tires and no spacers right now. On mine, it only rubs a little at full left turn. Nothing at full right. I'm going to put spacers on. Mostly because I like the look, but I don't think they are necessary on my rig.
