Wheel spacers and alignment
Old Apr 27, 2009 | 04:28 AM
jayrav's Avatar
Default Wheel spacers and alignment
Will installing a set of wheel spacers affect my current alignment?
Thanks!
Old Apr 27, 2009 | 05:07 AM
jayrav's Avatar
Originally Posted by Detn8RYellow
I installed a 2.5" lift, 33's & Wheel Spacers.. didn't need a alignment. If your are just adding spacers to your current setup then you will be good, the only thing it will change is the stance.
Yeah, that is what I figured, but wasn't 100% sure.
Thanks
Old Apr 27, 2009 | 05:11 AM
TINMAN080's Avatar
Added 1 1/2'' wheel spacers over 20,000 miles ago- no alignment issues. Tire wear excellent....
Old Apr 27, 2009 | 05:14 AM
jayrav's Avatar
Good to know
Thanks
Just so you guys know. I need the wheel spacers because of rubbing issues with my front coil overs.
Thanks again!
Old Apr 27, 2009 | 05:20 AM
jayrav's Avatar
BTW, did you guys notice a improvement in handling after installing the wheel spacers due to the wider stance?
Old Apr 27, 2009 | 05:35 AM
bOLsAK=3's Avatar
Since the Jeep has a 3" wider stance it would have seemed so. I really couldn't tell a huge difference myself but I never pushed it too hard into the corners either. I honestly couldn't tell too much of any change.
Old Apr 27, 2009 | 05:44 AM
jayrav's Avatar
I guess in theory it should provide a little extra stability by lowering COG. I'll see when I get mine installed.
Old Apr 27, 2009 | 03:38 PM
b14400's Avatar
Probably the best thing I have done to help improve stability at highway speed. Very noticable improvement especially at 70 plus with a quartering wind.
Old Apr 27, 2009 | 03:57 PM
jayrav's Avatar
I sure hope to notice the same improvement. Thanks for your input!
