Are wheel spacers needed?
Old Apr 24, 2009 | 05:04 PM
JOOP MAN's Avatar
Default Are wheel spacers needed?
Next weekend Im putting on a 5 inch trailmaster kit and going with 37x12.50x17 Goodyears ,the wheels are 17x8 with 4.76 back spacing. So are wheel spacers necessary?
Old Apr 24, 2009 | 05:20 PM
Dante's Avatar
What is the width of the wheel you are using?
Old Apr 24, 2009 | 05:40 PM
nthinuf's Avatar
Here is the answer from the FAQ here in the Modified section. Good place to start...
https://www.jk-forum.com/forums/show...74&postcount=3
Q: What back spacing will I need on my wheels in order to clear 12.50 wide tires?
A: I would recommend that you do not exceed 4.75" of back spacing and even at that, you may still have some minor rubbing up front at a full turn. Also, I would recommend that you do not go any less than 3.75" as anything less would cause your tires to stick out very far past the fender flares. Any back spacing within this range should work out great.
So, you're right on the border of the 'suggested' BS. Maybe a little trimming or playing with your steering stops?
Old Apr 24, 2009 | 09:02 PM
rjhoop's Avatar
nope you will be fine without em!!!!front stock air dam????thats gonna rub rip it off!!!
