Wheel Spacers Retorque
Old Dec 16, 2007 | 01:38 PM
Jeepin Down South's Avatar
Default Wheel Spacers Retorque
I know this is a dumb question but i'm new to wheel spacers. After 100 miles when I retorque do I have to take off the tires/wheels or keep them on and retorque just the lugs from the outside.
Old Dec 16, 2007 | 01:40 PM
Robar's Avatar
You need to take the wheels off and retorque the spacers then replace the wheels.
Old Dec 16, 2007 | 01:43 PM
wayoflife's Avatar
JK-Forum Founder
What Robar said. The aluminum wheel spacers can crush a bit on install and you're just double checking to make sure this has not happend or if it has, to make up the difference.
Old Dec 16, 2007 | 02:28 PM
Alaska-HWY JK's Avatar
I retorqued my Spidertrax spacers 5 ft lbs less than the origional torque and only one out of 20 made up a bit more. It may have not been pressed in quite as much at the factory. I check them when I rotate the tires and nothing has budged since then.
Old Dec 16, 2007 | 04:49 PM
mkjeep's Avatar
Same here with spidertrax, haven't moved, I have 14,000 miles on the jk, put them on about 6000, no probs and I check them regularly
