Wheel/Tire combo width ?
Old Jan 4, 2012 | 09:55 AM
Ironside's Avatar
Default Wheel/Tire combo width ?
Need some expert opinions. Getting ready to pull the pin on a 2.5"-3" coil lift. Im running FUEL Boost rims. 18x9 5" of BS. My 3.73 gears suck....so I am going to run 33" Toyo open country M/T's until I swap gears. Here is my question. With the wheel BS will the 33x12.50 be too wide? Is it a safer bet to run 275/70/18's? (11" width)
Old Jan 5, 2012 | 02:16 PM
Discount Tire's Avatar
Sponsoring Vendor
The 275/70-18 size is a little to narrow for a 9" wide wheel and the 33x12.50-18 size is going to be a tight fit with a 5" BS wheel. The 33x12.50-18 is the better option but I recommend test fitting the tire first to see how it's going to work.
Another option you may want to consider is the DuraTrac in size 295/65-18.
Old Jan 6, 2012 | 08:53 AM
Ironside's Avatar
Thanks for the reply. Im running Duratracs on my Superduty and Love them. Wanted to give the OC MT's a shot but not at the risk of making the JK useless....
