Wheel vibration
Old Jan 3, 2013 | 12:23 PM
JasonM's Avatar
Default Wheel vibration
Need help figuring out a problem. Lifted my rubicon 3.5 inches. Running 35 inch tires. When i hit a bump at 20 to 30 mph my steering wheel jerks around . It doesnt do this at higher speeds. Any suggestions?
Old Jan 10, 2013 | 05:38 PM
LBJEEPER's Avatar
I would start with double checking the torque on all your suspension links and track bar. If that doesn't work maybe look into the steering stabilizer or ball joints. That's my best guess, hope it helps
Old Jan 10, 2013 | 06:12 PM
Jayrubicon's Avatar
Sounds like typical bump steer.. As long as the jerking wheel isn't a continuous, violent shake which is death wobble.
Bump steer is almost always steering geometry related.
Do you have a track bar drop bracket ? If your drag link and track bar are too far off from running at the same angle it will certainly cause it.
Old Jan 10, 2013 | 07:27 PM
planman's Avatar
Forum Tech Advisor
Are you running longer front control arms to correct your caster alignment spec?
Did you loosen all your control arm and trackbar bolts and wait to re-torque them until the wheels and tires were back on with the full weight of the vehicle on the ground?
Did your lift include an adjustable front trackbar, or did it include a trackbar relocation bracket combined with a drop pitman arm?
