wheel vibration?
Old Sep 7, 2013 | 01:42 PM
13commandojk's Avatar
Default wheel vibration?
I got the wheels re balanced/alignment done/ tightened all the bolts on the susp. And it still have a very slight vibration at 40-50mph. Its not horrible, but its noticeable. What else should i look into?
Old Sep 7, 2013 | 02:30 PM
planman's Avatar
Forum Tech Advisor
Did you remove the lug retainer clips when upgrading to aftermarket wheels or installation of wheel spacers?
Old Sep 7, 2013 | 02:31 PM
not sure shop installed it for me, i'll check into that. Those just the lil lock rings that go around the studs?
Old Sep 7, 2013 | 05:28 PM
planman's Avatar
Forum Tech Advisor
Correct. They are not on every stud. If they were not removed, the wheel cannot be flush against the hub/disc.
Old Sep 7, 2013 | 06:21 PM
Good call, i definatley didnt think to look into that. I'll check it out in the morning and see. Thanks
