wheels
Old Mar 2, 2010 | 10:04 AM
dmick33's Avatar
Default wheels
I have a question on wheel sizes and how they look. If I get a 12.5 inch wide tire in a 33 and put it on a 15 or 16 inch rim with enough backspacing not to rub which one will stick out further or will they be the same?
Old Mar 2, 2010 | 10:32 AM
IcyFridge's Avatar
It all depends on the backspacing you have on your wheels. The less backspacing you have, the more it sticks out. I am happy with my 17"x8" wheels with 4.5" backspacing. It sticks out about an inch with my 285/70R17 tires.
There are some threads about 15 inch wheels hitting the brake calipers on our JKs. The 16s would be a better bet.
Old Mar 2, 2010 | 10:51 AM
dmick33's Avatar
What do you need to clear the 15s?
Old Mar 2, 2010 | 11:37 AM
jeepherder's Avatar
Default 15s
a 4in side grinder on the left front caliper was all I needed on my 08 Rubi.
Old Mar 2, 2010 | 12:08 PM
revolucion!'s Avatar
x2 on this. you need to check the backspacing.
Old Mar 2, 2010 | 12:44 PM
dmick33's Avatar
what would i need to run the 15s? What would i need to run the 16s?
Old Mar 2, 2010 | 12:51 PM
atuldo's Avatar
https://www.jk-forum.com/forums/sponsoring-manufacturers-vendors-check-out-cyber-monday-specials-24/15-alloy-wheels-vs-15-steel-wheels-120933/
Old Mar 2, 2010 | 12:53 PM
stlfan06's Avatar
Tires.....a jeep.....
What are you asking? Specifically.
Old Mar 2, 2010 | 01:29 PM
dmick33's Avatar
What backspacing for each wheel size to run a 12.5 wide tire?
Old Mar 2, 2010 | 01:33 PM
bradj1964's Avatar
I have 15x8 3.75 backspacing american outlaw 2 wheels with 33x12.50x15 bf goodrich all terrains, no problems rubbing the brake calipers or any other problems here, I have a 08 4 door X model unlimited by the way
