Wheels/backspacing
I currently have a stock 2012 jk. It has the 17in wheels. I'm looking to go aftermarket. I'm thinking of going with 16 inch m/t with 33's. Can someone help me with the backspacing? I was hoping to have a wider stance on either side so the tires stick out more then the stock ones. I believe the stock wheels have a backspace of 6.5 inches. Ideas?
Backspacing only carries meaning relative to your actual rim width.
So, a 17x9 rim with 4.5" backspacing is also called a zero offset wheel. That means the back spacing is in the middle of the wheel's width.
The more negative the offset the more a wheel (and tire) will "suck in" to your jeep. The greater the positive offset, the more they will stick out. Rim height - 16", 17", etc. - won't have any impact on your vehicle's stance.
an 8" wide rim with a 4" backspace, or a 9" wide rime with a 4.5" back space are both a zero offset but one extends 1/2" both inward and outwards on your jeep.
Most people run a 9" wide rim with 4.5" of backspace. This could be a 16" rim as you mention or a 17" rim as referenced in the replies above.
I run a 17x9.5" rim with a 4" back space. That means my wheels (and tires) stick out quite a bit. However, even with this offset, my tires still rub on my frame under compression. I run a 14.50 wide tire.
Sorry if this is confusing.
I hope it helps!
Enjoy!
I hope it helps!
Enjoy!
Consider your likely suspension upgrades carefully when purchasing wheels. The suspension parts and frame can rub. I think the EVO bolt on kit specs recommend 3.75" or less backspacing. My Teraflex kit required 4.5 or less. I have 4.75 backspacing on 17x9 wheels with 35" KM2 and there isn't any rub. Like said above, wider than a 9" wheel will require less backspacing to provide the same clearance from the suspension or other parts.
Check the FAQ for more information on Wheels and Tires
