wheels rubbing.
Old Jan 6, 2012 | 07:59 AM
LESTERAA's Avatar
Default wheels rubbing.
Do 20x12 wheels rub on a 10 jk sahara unlimited without any modifications.
Old Jan 6, 2012 | 02:06 PM
JnT's Avatar
JnT
ummmmmm it would depend on your tires and backspacing of the wheels.....
Old Jan 8, 2012 | 05:44 AM
JKU Rubicon's Avatar
20x12 wheels
Old Jan 8, 2012 | 06:49 AM
JnT's Avatar
JnT
Maybe he means 20" rims that are 12" wide?
Old Jan 8, 2012 | 10:19 AM
LESTERAA's Avatar
Yes exactly that.
Old Jan 9, 2012 | 07:10 AM
JnT's Avatar
JnT
So like I originally replied, it will depend on the backspacing of your wheels AND the tires you put on them. Without knowing the tire size we can't answer your question. It will also depend on what you're using your Jeep for. If you're building a mall crawler then you can go bigger tires, if you're off roading then you have go stay smaller, although I don't know why you would want 20's for offroading....
Old Jan 11, 2012 | 10:52 AM
LESTERAA's Avatar
Honestly someone told me to and I was gullible. But now I've decided 17 rims w 33 tires. I also want to add a four inch lift to it. Do you think 33 is too small. If so what's biggest without gear changing.
Old Jan 11, 2012 | 11:13 AM
pbloom95's Avatar
If you have a manual you can defiantly go to 35s without regearing.
Old Jan 11, 2012 | 02:42 PM
LESTERAA's Avatar
Automatic.
Old Jan 11, 2012 | 03:02 PM
jckid's Avatar
Automatic.
I would stick with 33's if you don't plan to regear. But I wouldn't do over a 2.5" or 3" lift with 33's. A 4" lift would look much better with 35's. And good idea on sticking with the 17" wheel size.
