When to flash Jeep for regear...
Old Aug 23, 2010 | 01:44 PM
Cedo Nulli's Avatar
Default When to flash Jeep for regear...
I'm about to get 5.13s installed and just picked up a Superchips Flashpac. Since I'm going to use it to recalibrate the auto trans for the new gears/tires, etc, when 'should' I flash it, before the gears so the auto trans is already setup for the new gear ratio or let the gears break in on the stock 4.10 setting before I reflash it?
Does it make a difference? I don't think it matters either way, but if there is a reason why I shouldn't flash until the new gears are broken in, I'd like to know instead of blowing them up.
Old Aug 23, 2010 | 01:54 PM
JayhawkJeep's Avatar
Veteran: Navy
You can flash it before the re gear if you want(why not?). Just once you get the new gears change the gear setting.
Robar's Avatar
I don't think it makes a difference about the break in. I would flash the new gears when they are installed.
Old Aug 23, 2010 | 02:05 PM
dmhines's Avatar
I flashed mine when I dropped it off. That why it was right for any test rides the installer did.
Old Aug 23, 2010 | 02:06 PM
SilverJK12's Avatar
Good call! Thats what my plan is in a bit when I get 4.88 done
Old Aug 23, 2010 | 02:22 PM
rubi08unlimited's Avatar
I don't think that the flashpaq actually adjusts any shift points. It will recalibrate the speedometer but I think that's it. I haven't noticed any difference in shift points. I tried altering the tire size to see if it would adjust shift points but they remained the same.
Old Aug 23, 2010 | 03:38 PM
JPop's Avatar
The Flashpaq definitely adjusts shift points and firmness.
Old Aug 23, 2010 | 06:47 PM
Stoneaxe's Avatar
For certain.
Old Aug 23, 2010 | 07:27 PM
based on tire size? by all means, I'd love it if that's true. that's one of the reasons I bought it. I know the tunes change the firmness of the shift, I can feel that, but I'd like to know for sure if it changes the shift points. Does it make that claim on their website?
Old Aug 23, 2010 | 10:36 PM
captjay's Avatar
flash as soon as you can, if you flash before the swap, i would do it the morning of the drop off or whenever u take it in. u might have problems driving there but just watch yourself and give plenty of distance ahead of you. i did mine when i got home from the gear swap, it was not a fun 30 miles. the tranny wouldnt shift correctly and the esp kept kicking in for some reason. but i did have 37s, lift, and 5.13 gears installed at the same time. for the auto tranny, u will notice a difference immediately after the gear install without the flash
