where is the axel nut?
Sorry for the noob question. I have an annoying chirp chirp chirp noise coming from my front right wheel. I changed the brakes, rotor, used new brake clips, greases everything up..still chirping. It seems to stop when I press the brake pedal..even lightly. Also seems to be worse when I am taking a curve. I have also noticed that sometimes I won't hear it until I hit a bump or pothole than it will start.
I can't think of what it could be but someone told me to check my axel nut to make sure it's tourque to spec.
Where the heck is the axel nut?
Brake dust disc the splash shield right? I checked that and while it is pretty close to the rotor..it wasn't touching it.
Would a bad ujoint have those symptoms?
It's the worst when I am in a curve...for example like a crescent shaped entrance /exit ramp for interstate
Also noticed that often it won't be doing it until I hit a bump or pothole than it will chirp a few times and stop when I tap brakes..than start back after releasing brake
It's not loud..just enough to drive me nuckin futs. Only hear it when top off or Windows down and music off
My rear brakes do the exact same thing your describing. I think my axle flange is bent. Not sure what would cause it on front except warped rotor. But you just replaced everything so im not sure.
Thanks for the help
