Where did you mount you Warn wireless receiver?
Old Apr 16, 2015 | 10:48 AM
cuongdyna's Avatar
Default Where did you mount you Warn wireless receiver?
Hey everyone
Thanks
Tran
Old Apr 16, 2015 | 01:24 PM
Cat Dr.'s Avatar
Default Warn wireless receiver.
I have a 2008 JK. I mounted it on the left driver compartment wall by the clutch petal. High enough should I get into deep water but not too high to service. I extended the wires and ran them thru the foam under the winshield on the drivers side. Works great. Good luck
Old Apr 16, 2015 | 04:29 PM
cuongdyna's Avatar
Thanks I'll look into doing that.
So your cable is plugged into your wench all the time?
Old Apr 16, 2015 | 06:29 PM
Woody's Avatar
Vet Army
Be aware of parasitic drain on your battery if left plugged in for extended periods of time. I just plug mine in when leaving the pavement and remove when back on solid ground.
Old Apr 16, 2015 | 07:42 PM
cuongdyna's Avatar
Found a spot for the receiver. its unplugged and when I went to use it I would plug it in.
Old Apr 19, 2015 | 03:34 PM
Cat Dr.'s Avatar
No, I only plug it in when I go to use my winch. The heat under my hood is pretty high when wheeling. It melted the pressure gauge for my Kilby on board air system after my first trip. I would be cautious of mounting the wireless receiver under the hood. My block for the relief valve,pressure switch and gauge were mounted just to the rear of where you mounted your receiver so I am pretty confident there will be a lot of heat in that area. Does your hood have vents or is it stock?
Old Apr 30, 2015 | 09:10 PM
cuongdyna's Avatar
It's a shock hood. I'll keep my eye on it.
