Whirring noise......?....driveshaft...?
Old 12-11-2009, 04:01 PM
ironworkerlu21's Avatar
Default Whirring noise......?....driveshaft...?
OK.....so i got the driveshaft install all done and back on the road, great! But now there seems to be a shirring noise, almost like a whining, kinda like a gear driven HP motor, coming from under the Jeep. It gets louder with the speed of the Jeep, and eventually it's drowned out by the noise of the tires, and soft top.
Could i have tightened the nut that holds the yokes on too tight? Maybe slightly crushing the bearings?
Old 12-11-2009, 04:20 PM
jkman77's Avatar
Did you retorque the pinion nut to 150 foot pounds. And you need to check pinion preload as you do this.
Old 12-11-2009, 04:54 PM
BlackNorthernJK's Avatar
ya, I would definately check the pinion nut again
Old 12-13-2009, 05:28 AM
negative on the pinion nut preload check.....pretty sure this means i need to take her all back off, huh......Damn it man
Old 12-13-2009, 08:12 AM
jaker t5's Avatar
does it still make the noise when you have in in nuetral
Old 12-13-2009, 12:18 PM
Yep......pretty sure
Quick Reply: Whirring noise......?....driveshaft...?
