White lithium grease
Old Apr 13, 2013 | 11:27 AM
Jackedup's Avatar
Default White lithium grease
Ok, I bought the hyline bumper w/ tire carrier and the instructions say to use a grease gun and white lithium grease to lubricant the spindle of the tire carrier as I open and close the tailgate as far as possible to spread the grease evenly. Well I've been to four auto parts stores and none of them Carrie whet lithium grease in tube for grease gun, only in a hand squeeze tube. Lowes or Home Depot doesn't sell it either . So I don't know what to do. Should I just use a marine grade or water proof grease? Any suggestions?
Old Apr 13, 2013 | 11:55 AM
Boyerracing343's Avatar
Go to local auto parts store and get white lithium grease in a spray can. Just like brake clean comes in. It will work fine.
Old Apr 13, 2013 | 11:57 AM
Jackedup's Avatar
I can't use a spray can to pump grease into a zerk fitting for the tire carrier
Old Apr 13, 2013 | 12:01 PM
Ncb's Avatar
Ncb
General grease for suspension components should be fine.
Old Apr 13, 2013 | 12:02 PM
Riznoy's Avatar
Check this out on AMZN: Star Brite Multi Purpose Lithium Grease Cartridge (14-Oun... http:/ / a mzn.com/B004A7DKVK
Hope this helps
Old Apr 13, 2013 | 01:38 PM
shockwaveaz's Avatar
I would use the right grease. Some will break down rubber and plastic. That is why they say to use white lithium grease.
😂 Sent from my Galaxy Note 2 😂
Old Apr 13, 2013 | 03:17 PM
Ryan0260's Avatar
Just get the white lithium grease in the hand squeeze tube. Should work fine.
Old Apr 13, 2013 | 06:17 PM
Jackedup's Avatar
How do you suggest I get it from the hand squeeze tube into the zerk fitting?
Old Apr 13, 2013 | 06:44 PM
Pushrod's Avatar
I have always used EP3 general purpose grease on mine, there are no components the grease will damage in there, just metal.
Old Apr 13, 2013 | 08:54 PM
Just saw some at oreilly. It was the mini cartridge for 4.00. Grainger has it also. .. Not sure what stores you have there.
