Why does lift height regulate shock and bumpstop length?
Old Nov 29, 2009 | 11:32 AM
style_front's Avatar
When I think about bump stop leangth should only increase when tire diameter increases and to me the bump stops should increase In a 1-2 ratio. Add two inches of tire add 1 inch of bump stop, and now that you've added 1 inch of bpstop you can afford an extra inch of shock body.....
Old Nov 29, 2009 | 11:34 AM
I've seen planmans rig, very nicely done and he's made several wonderful write ups
Old Nov 29, 2009 | 12:12 PM
nthinuf's Avatar
Originally Posted by style_front
Bump stop height=lift height? Can you expand? Does that mean if I lift 4 inches I should extend my stops 4 inches?
From the FAQ's that we've all read, right?
Q: Do I need to install bump stop extensions?
A: Yes. Bump stop extensions are designed to prevent the over compression of your coils and are absolutely necessary. Bump stop extensions can also help prevent the rubbing of fender flares at a full stuff as well as the bottoming out of shocks.
Q: What size bump stop extensions should I install with my lift?
A: Typically, you'll want bump stop extensions that are approximately as tall as the lift you just installed on your Jeep. In other words, if you lift your jeep 2", you'll want bump stop extensions that are about 2" tall. Now, I do say 'typically' as this is just a guide to follow and not necessarily a rule. Depending on the actual height of the coil, thickness of the wire used and the amount of winds it has, the rules can change.
The other variable to consider is whether or not you'll be disconnecting, as that will add a few inches of travel as well...
Old Nov 29, 2009 | 12:29 PM
thanks for the cut n paste nthn, I wasn't giving as much consideration to the coils I guess and was focused on simply stuffing the tires.....
Old Nov 29, 2009 | 12:32 PM
river2c's Avatar
Umm, I disagree. I want the extra articulation, there are clips and guides that make it perfectly fine for your spring to leave it's perch momentarily and using the tire size as a benchmark would dictate bumpstop and shock body length and prevent over compressing and ruining the shock.
Without spring retainers, what's to keep your springs from popping out at the worst possible time on the trail? Shocks (or mounting brackets) will fail if over extended or over compressed. Are you saying to let your tires hit the wheel well and act as the bump stops? This doesn't sound like a very well thought out theory. Let me know if I am missing something.
Old Nov 29, 2009 | 12:36 PM
river2c's Avatar
As a general rule of thumb, yes. You may be able to get away with less depending on what lift components you have.
Old Nov 29, 2009 | 01:10 PM
What other lift components do bump stop length depend on?
Old Nov 29, 2009 | 01:13 PM
Spring Clips/spring retainers, same thing I thought. Have there been reports of bracket failure from overextension of the JK or is it just a possibility? Of course I wasn't suggesting to use your tires as a bump stop I was suggesting we use the tire height of the tire to factor bump stop length opposed to spring lift height.
Old Nov 29, 2009 | 01:19 PM
nthinuf's Avatar
What other lift components do bump stops depend on?
As I mentioned in my first post,
If you trim the fenders or go to flats, you negate the need for extra bumpstop to prevent rubbing from uptravel.
If your coils are designed to be able to stack without damage, you can get away with running less bumpstop. (assuming your shocks are not bottoming out, making them act as the bumpstop. And assuming you're comfortable with the metal to metal jarring you'll get on impacts instead of the milder compression from the rubber/poly bumpstops compressing)
My experience with bumpstops:
OME HD + spacer, appx 4" of lift. Disconnected, my 32" (actual height on vehicle) tires rubbed the fenders enough to rip them off, and the coil was fully stacked. Added 2" lower bumpstops - coil compresses to an acceptable level, and the tire/fender rubbing is very light. I will trim the fenders a bit instead of added more bumpstop. With 35" tires, there would be no choice but to add more bumpstop or go to flat flares. (which goes right back to 'lift height = bumpstop height'
Old Nov 29, 2009 | 01:30 PM
Well I was asking/hoping river was bringing light to some thing not previously discussed, just trying to get a grasp on all of the angles here.
Lets isolate a bit, my lift is a rock krawler 3.5 entry level lift and my intent will be to put 37's. I am still piecing together some support parts for the entry level kit and I currently have river raider fronts and hacked rears so there is plenty of space.
Why would I have metal on metal jarring? My factory bump stops dont have metal on metal jarring so why would an extended bump stop that just didn't fit the proptocol of one inch extension for 1 inch of lift cause metal on metal contact?
