why are some lifts made 2dr or 4dr some both
why are some lifts make just for the 2dr or 4dr then some kits are universal between the two?
what happens if u put a 2dr lift on a 4dr??
Sponsoring Manufacturer
Rough Country Representative
Different spring rates for the difference in weight. If you were to put a 2dr kit on a 4dr you wouldnt get the advertised lift out of it.
if you put a 4dr lift on a 2dr, you will get more lift. for instance, TF used to make 1 kit for 2drs and 4drs. the 2.5" coil lift would give a 2dr about 3.5" and the 4dr between 2.5-3". factory suspension is the same. if you put 4dr rubicon with tow pkg, dual top option suspension on a less equipped 4dr or 2dr x/sport/sahara, you will get more lift.
