Wierd sound in reverse HELP
Old Feb 13, 2013 | 04:15 AM
jkd3624's Avatar
Default Wierd sound in reverse HELP
So I get a wired sound when I'm on ice and I get excessive wheel spin in reverse. I have 35" tires with a 3.5" lift and cam bolts so my pinion angle isn't perfect. The only way I can describe the sound is when you start to bounce the front end trying to climb a hill it's sounds the same in the back when in reverse and my wheels spin. Anyone ave any idea what it can be oh and I have the stock drive shaft still and 3.21 open diffs. Standard shift.
Old Feb 13, 2013 | 05:34 AM
jkd3624's Avatar
Bump.."....
Old Feb 13, 2013 | 05:39 AM
Sahara_Steve's Avatar
you in 4wheel or 2 when this happens? traction control on or off? I'm not really that technical or mechanically inclined but my Jeep makes all kinda noises when slipping in snow and ice. Also does this happen when on dry pavement or just ice?
Old Feb 13, 2013 | 06:25 AM
jkd3624's Avatar
Two wheel traction control off and only on ice as it grabs on pavement.
Old Feb 13, 2013 | 03:13 PM
jkd3624's Avatar
Bump............
