Will 15 inch wheels fit on a jk?
Old Jan 13, 2007 | 08:04 AM
IFSAR's Avatar
Default Will 15 inch wheels fit on a jk?
I have decided to go with a 3" Teraflex suspension, 35X12.50x15 BFG krawlers and Procomp 15x8 steel wheels (5 on 5). These wheels have a backspacing of 3.75".
My question is this, will these wheels fit over the break calipers or is rubbing likely? 15 inch wheels and tires are so much cheaper than 17's;I would like to go that route if possible.
Old Jan 14, 2007 | 09:36 AM
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
I believe that these will fit. Just do a little digging around the forum, and you'll find info. Search also for Cragar Soft 8s.
Here's a place to start;
https://www.jk-forum.com/forums/stock-jk-tech-12/will-15-s-fit-1994/
Old Jan 14, 2007 | 02:13 PM
im4degreesaboveu's Avatar
i was told by a friend of mine that works at discount tire that 15"s will not fit cause of the bigger brakes
Old Jan 14, 2007 | 02:48 PM
Jake_Blues's Avatar
Some 15" wheels will fit, some won't. I personally wouldn't run them. Even if you find one that fits correctly, who knows what happens when you get the brakes nice and hot and things start expanding, or when you're flexing everything on a trail.
-E
