Will AFE y pipe not work on 2012 2 door?
Old Jan 3, 2012 | 05:49 PM
Vinson Clark's Avatar
Default Will AFE y pipe not work on 2012 2 door?
I was looking on AFE site and noticed there y pipe says 4 door only unless I looked over something. So correct me if I'm wrong the only option us 2 door guys have is the teraflex spacers?
Old Jan 3, 2012 | 06:13 PM
thedrod's Avatar
You should call teraflex. I am pretty sure if you change your front driveshaft to a 1310 which has a smaller diameter than the stock driveshaft, and use the spacers you should have a good amount of clearance if you stay under 4 inches of lift and use the proper length shocks.
Old Jan 3, 2012 | 06:49 PM
OutlawJK's Avatar
Quadratec lists them for both I've heard
Sent from my iPhone
I will prolly give them a call tomorrow. I will be running a coast 1310 front shaft
Old Jan 3, 2012 | 06:56 PM
Sent from my iPhone
You are correct I will have to look into this
Old Jan 10, 2012 | 08:05 PM
coleadcock1234's Avatar
you should have got a 4dr rubicon instead of that little dinky 2dr. just saying
Old Jan 12, 2012 | 02:31 PM
OutlawJK's Avatar
Well it looks like the difference is the fuel tank
Its too far forward to use the AFE
On a 2 door
Sent from my iPhone
