Will this fit?
Otherwise you'd see stock 4 door Rubi's running 35's aloooot more if it were that simple. A budget boost will run you around $100-150. Coils will obviously be a little more.
No, the 4.5" backspacing will not stick out as much as your current wheels...so you should seriously consider at least a budget boost/puck lift. Especially if you're not doing the work yourself...it'll cost you more down the road. If you are doing the work yourself...you can try, but you'd be wasting your time.
Those 315/75/16's are a 35x12.5 tire.
Is 4.5'' of backspacing good or bad as far as rubbing and clearing the caliper?
The general recommendation you will see for 35x12.50's is a 4.50" backspace. This is for clearance inward - the frame/links/arms/etc. As noted several times, you are still likely to rub on things like flares/pinch seam/rubi rails/etc.
In other words, would these stick out as much as the current 3.75'' backspace wheels I have or not?
I'm trackin. Thanks for taking the time to explain this!
The Jeep in my avi is my old 4 door. I'm now in a 2 door so the rubi takeoffs would bring me up an inch or an inch and a half....you think that would be enough to run 35s? If not, how bout I throw a puck in there, would that be enough?
Also, would 16x8.5 5-127.00 -6 tires fit on a 315/75/16 wheel?
Alternatively, I'm looking at some 35x12.5x15 on my current rim. Don't know if this has much of a difference as far as rubbing is concerned considering the back spacing is .75'' less. Would I be faced with the same problems as the tires listed above?
I'm trackin. Thanks for taking the time to explain this! The Jeep in my avi is my old 4 door. I'm now in a 2 door so the rubi takeoffs would bring me up an inch or an inch and a half....you think that would be enough to run 35s? If not, how bout I throw a puck in there, would that be enough? Also, would 16x8.5 5-127.00 -6 tires fit on a 315/75/16 wheel? Alternatively, I'm looking at some 35x12.5x15 on my current rim. Don't know if this has much of a difference as far as rubbing is concerned considering the back spacing is .75'' less. Would I be faced with the same problems as the tires listed above?
I was running 35x12.5's on a 15x8 wheel, so you'll have absolutely no problems. I was able to air down to 8psi and never blew a bead (even on some very flexy trails). The 8" wide wheel will act as a "poor-mans beadlocks" so it's actually a good thing. Would make more sense than moving up 1" in wheel diameter.
The stance with 3.75" backspacing had absolutely no issues....and it looked nice! I say go for it!
