Will gears help mpg
No wonder 37's are the "new" 35's!!! This would explain a lot!!!O.K. though back to the original post,
How about a 2012 JKU Rubicon with 6spd transmission, stock 4:10's and 37 BFG KM2's? Would my gas mileage improve from re-gearing? I know my low end power will increase.
thanks,
Jacob
I'm an 11 with 35s and just installed 5.13 gears. I have seen an increase on average so far of 1 mpg.... Which brings me around 13.5 mpg average.... It could be from me going easy during the break in period but I have only had a tank at 13 or above once before and it was a tank on all highway miles.
I'm happy with the increase... I'll take anything so long as its not a loss.
Looks like another case of listening to the self proclaimed experts and going too low in the gears. The mileage will just get worse once the break in period is over and you start driving normally.
Originally Posted by CJ7nvrstk
13.5! That sucks. My guess is that you went too low with your gears and your motor is spinning faster than it needs to be. You probably would have been much better off with 4.56s since your only running a 35. I was getting 15.5ish on my 08 with 37s and 5.13s. Now why would I get better mileage even though running a bigger/heavier tire combo? (37x14.5 heavy assed toyos) Cuz my motor wasn't spinning as fast as yours is at freeway speeds, provided you are talking freeway speeds. Notice on your tach the nice solid green lines up to about 2200 rpm? That is where your motor is most efficient and my gues is that you are going over that a bit. Drop down your speed a bit and I'm sure you will notice your "ECO" will be on much more, and your mileage will improve a bit.
I jumped on to this thread to hope to get an answer as well, or at least some sort of clear idea based off of people with experience in the matter...
Its like every person on this thread has a different opinion and half of them have nothing to do with what the OP asked...
Was guna sub to this to see if anything comes to light that is actually helpful but lost hope on page 3...
Well there is a chart that will give you rpm at speed 70 with the gear size and tire size. The way I see it is if you have let's say 411 and your at 2000 rpm at 70 and then you go 513 and it puts you at 2700 rpm at 70 well that will hurt your fuel economy. Right ? Atleast that's what you would think. The higher the rpm the worse the gas mileage.
Not that easy. If you load the engine at more than 75% throttle blade position (not throttle pedal) you run in open loop and a fatter fuel mixture. You also wind up with more kick downs and more unlocking of the converter. The frequency of open loop, kick downs and unlocking of the converter is what robs efficiency.
