Will I need Wheel Spacers?
Old Jul 12, 2011 | 02:40 PM
awesomo's Avatar
Default Will I need Wheel Spacers?
I'm planning on upgrading from LT255/75R17 to LT285/75R17. Will I need wheel spacers to make this new tire size fit my 2011 JKU?
Also, advice between 285/75R17 vs 285/70R17?
Thanks in advance
Old Jul 12, 2011 | 03:03 PM
CreepJeep's Avatar
you will rub at full lock when you turn. I do.
Old Jul 12, 2011 | 03:55 PM
Zombie Hunter's Avatar
Thanks in advance
285/70R17
Section Width: 11.22in
Rim Diameter: 17 in
Rim Width Range: 7.5 - 9 in
Overall Diameter: 32.70 in
Sidewall Height: 7.85 in
Radius: 16.35 in
Circumference: 102.7 in
Revs per Mile: 636.0
285/75R17
Section Width: 11.22 in
Rim Diameter: 17 in
Rim Width Range: 7.5 - 9.5 in
Overall Diameter: 33.83 in
Sidewall Height: 8.41 in
Radius: 16.91 in
Circumference: 106.2 in
Revs per Mile: 614.8
Will vary slightly depending on manufacture.
Old Jul 12, 2011 | 03:59 PM
Dntouch's Avatar
Sorry man i just love your username and avatar...
Nothing to add here continue........
Old Jul 12, 2011 | 04:11 PM
MAMYAC's Avatar
I have the spacers with 35" tires and they work great. They also make the stance wider so the jeep looks much better to me. I love the wheel spacers. Just my $0.02.
Old Jul 12, 2011 | 04:19 PM
D_engel's Avatar
Go with the taller tire you'll wish you did if you don't.
I see you finally got some bigger rubber Karl. I though you love your short fatties
Old Jul 12, 2011 | 04:38 PM
Battlefrog's Avatar
The 35's were a 1 day deal, I'm still rockin the 31's for another 10-15k miles
And still loves his short fatties as well... Haha
Old Jul 12, 2011 | 04:39 PM
Battlefrog's Avatar
Thanks in advance
I can't see your profile because of my phone app. Are you running the stock rims still ?
Old Jul 12, 2011 | 06:44 PM
D_engel's Avatar
Looking at your wheel setup, I wish i had gone with 15x10 pc 8069's as oppose to my 15x8s. Yours has a wicked stance
Old Jul 12, 2011 | 06:49 PM
TexanJk's Avatar
Running stock wheels it is advised. You will rub a little as said above if not. I'm running 35's and have the spidertrax spacers with stock wheels. No rub, my $.02.
