Will it rub?
Old Feb 16, 2015 | 04:39 PM
Alpine Jeep's Avatar
Default Will it rub?
Will it rub?
2013 JKU sahara 2.5" lift, stock fenders, wanting to put on 37 x 12.5 on 17s
Will it rub?
Old Feb 16, 2015 | 04:42 PM
Jeepstin12's Avatar
Yes.....
Old Feb 16, 2015 | 04:46 PM
Originally Posted by Jeepstin12
Yes.....
Sorry, forgot the 1.25" spacers...now...will it rub?
Old Feb 16, 2015 | 05:02 PM
Jeepstin12's Avatar
On bumps, dips, sim,e off camber driveways and parking lots, yes. Off road, even worse. Why 37's?
Old Feb 16, 2015 | 05:03 PM
Because they are for sale, locally.
sea bass's Avatar
How much bumpstop? I would guess you'd need 4"+ of bumpstop.
Or trim them fenders!!
Old Feb 16, 2015 | 05:05 PM
It's just 2.5" pucks
Old Feb 16, 2015 | 05:15 PM
nthinuf's Avatar
Bumpstops - not coil spacers. They are inside the front coils, and outside the rear coils. Their job is to stop the axle/tires from moving upward. If you are not trimming the flares or buying flats, you will need to add taller bumpstops. Depending on how much room you have, you may not be able to add enough bumpstop. The upper/lower stops will either be contacting all the time, or they will not be tall enough to stop the tires from ripping the flares off.
And stock rims with 1.25" spacers? Not enough backspace to keep 37's off the frame/ca's/whatever when turning, especially with the suspension compressed. Find the writeup for adding spacers to the steer stops.
Old Feb 16, 2015 | 05:16 PM
Thanks. Sounds like 35s are in order then?
Old Feb 16, 2015 | 05:17 PM
JCDriller's Avatar
If all your running is the 2.5" spacer lift without bumpstops your going to risk really doing some damage with 37s. You can run this but I'm guessing your going to need 3.5-4" bump stops which means you won't have much up travel. Your pinch seams must be trimmed along with your rock rails if you've got them and you can gain some clearance by cutting the fenders. Glad to see you tossed in the 1.25 wheel adapters since you plan on using factory wheels. It can be done with a 2.5 budget boost, but its going to take a little more than what you've proposed.
if you want to run 37s with only the 2.5" budgets boost, look into getting a 1.25 or 1.5" body lift. This combined with proper bumps, wheel spacers and your budget boost will clear those 37s. Next issue is your axles.
