Will these wheels fit?
Hey guys, the winters here are starting to chew up my stock wheels a bit so i'm looking at getting some new wheels and tires come spring. I've found a few different wheels that I like but for the money I like these ones best...
http://www.quadratec.com/products/92808_5XX_A_PG.htm
Size: 17" x 8.5"
Product Description: DEJ CANNON MACHINED WITH CLEAR COAT 5x127
Backside Spacing (in): 4.99
Offset: -6mm
Load Rating: 1600
Weight: 43.43
Wondering if these will fit my rig and wondering if I can fit these tires on these wheels...
http://www.discounttire.com/dtcs/tir...il.do?pc=10809
I don't do alot of offroading so I dont need a really aggressive MT, but from what i've read and heard the Hankooks can hold their own on the trails.
Size: 17" x 8.5"
Offset: -6mm
Load Rating: 1600
Weight: 43.43
Those wheels wil fit on your JK.
They have 5" backspacing and the stock ones have 6.25", so they are equivalent to a stock wheel with 1.25" Terraflex spacers which some use.
Regarding the tire, your link doesn't work, but as long as they are 12.5" wide or less the backspacing should work fine.
I am not sure which Hankook you are looking at, but if you run a search, you will find several recent threads indicating that the rf10's are a good value for moderate trail usage.
Stock sensors will fit in any after market rim discount will just rebuild them for $6.00 a piece if you want to go with spacers which you won't need unless you are at 12.50 or wider go with Rough country 1.5 spacers only $59 a pair.
