Will this work?
Old Feb 12, 2014 | 03:35 PM
Cjsmith4's Avatar
Default Will this work?
This might be a silly question, but I figured I would ask because if the idea I have works, then I don't have to buy anything else.
So my current set up is 3" Teraflex lift with a relocation bracket on the axle side for the OEM track bar. Even with the relocation bracket, the axle is still not centered. I bought a Rock Krawler adjustable track bar thinking the relocation bracket came with it so I could just swap the OEM track bar and the Teraflex relocation bracket with all the Rock Krawler stuff.
Now here is my problem. When ordering, I didn't order the Rock Krawler track bar with the relocation bracket. I only got the track bar. I looked into a relocation bracket and realized Rock Krawler's bracket is a weld on bracket. I have NOOOO welding skills at all. So here are my questions.
What is the relocation bracket for in the first place? And can I use the Teraflex Relocation bracket with the Rock Krawler Trackbar. If so, it would save me a lot of time and money. If not, I am going to have to look into a different route. Thanks for any help you can give me.
Old Feb 12, 2014 | 04:07 PM
jaker t5's Avatar
If your stock bracket is still useable then just use it with your new TB , the relocation bracket is a cheap way to use your stock TB
Old Feb 12, 2014 | 04:16 PM
Cjsmith4's Avatar
This is the kit I have installed right now. The relocation bracket I currently have on is the one that is in this kit.
Teraflex 1251000 - TeraFlex 2.5" Lift Kit with Shocks for 07-14 Jeep® Wrangler Unlimited JK 4 Door - Quadratec
That is the bracket that I am curious about. Will it work with the Rock Krawler track bar.
If it is possible to just use the stock bracket, what is the point of a relocation bracket.
Old Feb 12, 2014 | 04:20 PM
Insidejob01's Avatar
I run a 2.5 lift with the rk track bar and it adjust to center it you have no need for another bracket just use stock locations.
Like said before relocation brackets are just a cheap fix to use a stock track bar
Old Feb 12, 2014 | 04:24 PM
Cjsmith4's Avatar
Okay, I now see why I was confused. I thought that was the purpose of a relocation bracket.
Here is where my confusion came in. I was looking at quadratec and saw this.
Rock Krawler Suspension JKC0001 - Rock Krawler Bomb Proof Rear Track Bar and Bracket for 07-14 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
Just now realized that comes with a bracket because it is not adjustable.
Thank you for quickly talking me through my confusion. Now I feel dumb. haha. Thanks guys!
Old Feb 12, 2014 | 04:25 PM
Cjsmith4's Avatar
But when you look at this:
Rock Krawler Suspension RK02026 - Rock Krawler Bomb Proof Adjustable Rear Track Bar for 07-14 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
It says under the product details that it needs a relocation bracket on the axle side. Why, if it is adjustable?
Old Feb 12, 2014 | 04:30 PM
jaker t5's Avatar
My fault a little here I was thinking of the front TB
that rear teraflex TB bracket is what you need because you are lifted above 2.5 , so with your new TB use that bracket also
Old Feb 12, 2014 | 04:32 PM
Cjsmith4's Avatar
My fault a little here I was thinking of the front TB , that rear teraflex TB bracket is what you need because you are lifted , so with your new TB use that bracket
okay, so just confirming what you are saying. I can use the Teraflex relocation bracket with the Rock Krawler Track Bar instead of using the Rock Krawler Relocation Bracket. Just confirming before I start pulling things apart.
Old Feb 12, 2014 | 04:39 PM
jaker t5's Avatar
Yes you can
Old Feb 12, 2014 | 04:41 PM
Cjsmith4's Avatar
Yes you can
Thank you much...now I have to wait for the Olympic Speed Skating to be over before I start working on it. I will work on it during the Figure Skating that is on tonight.
