will this work?
Old Feb 9, 2009 | 07:17 AM
ckmehl's Avatar
Default will this work?
08' JK X
2.5 in lift
1 in body lift
315 / 75/ 16 in tires if they will fit
on stock wheels with spacer.
or should i leave out the 1 in body lift. i just figured that it would be better with the 35's for more clearance.
for lift i'm looking at TF 2.5 complete
RC 2.5
2.5 Old Man EMU lgt/med
how does this sound for a start to a never ending fun job.
Old Feb 9, 2009 | 07:34 AM
hammerhead's Avatar
You shouldn't need the 1" BL with TF 2.5 coil lift or OME HD. With the RC or the OME LD you would be fine around town and rub when flexed without a BL. The RC 2.5 coil lift and their 1.25 BL would look great with 35's and not rub. You will need wheel spacers with 35"s and stock wheels.
Old Feb 9, 2009 | 07:38 AM
sacdaddy03's Avatar
Originally Posted by ckmehl
08' JK X
2.5 in lift
1 in body lift
RC 2.5
Sounds good....They will fit far as fender well, but the problem is stock wheel back spacing! The tires are going to rub the rear sway bar link!!
and that is with 285/75R16's....And 315's might rub alittle off road without the body lift!
