winch advise
Old Nov 20, 2009 | 06:07 AM
  #21
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Originally Posted by pjk
thank you for your insight. i am listening and getting back to what dave at northridge (and you) originally recommended = 9.5Ti. does anyone know what this may weigh in at with synthetic line? i have to do more research now. i wanted to stay with warn because it appears to be the "best" but we;ll see ? the ramsey 8.5e that woods recommneded sounds nice and cheaper $.
thanks again
Thanks for the good stuff about the bumper.
I don't thank anybody who knows winches is going to say that Warn is better than Ramsey. Ramsey winches are on more tow trucks than any other winch. Does Warn offer a lifetime warranty? Both are made it the USA and I wouldn't regard either as better. They are both top notch.
Ramsey does not offer what I would call a racing winch though. And the 9.0rc is what I'd consider a racing winch.
Old Nov 20, 2009 | 01:22 PM
  #22
Cdash's Avatar
I agree with your light weight approach like I said before, and I would like to do it that way.
The advice you getting is people's opinions. Non of them are wrong, if fact you would probably do quite well with any of the choices that have been suggested. There a lots of people that say they are satisfied with Harbor Freight and Smittybuilt winches. The brands thrown out here will all do you well.
Good luck with the decision - never seems to be as easy as it should......
Old Nov 20, 2009 | 06:05 PM
  #23
08leocon's Avatar
Originally Posted by Northridge4x4
Here is the other issue.
Specs for the 9.0RC
PERFORMANCE SPECIFICATIONS
Line Pull
Lbs.(Kgs.) Line Speed
FT./min(M/min.) Motor
Current Pull by layer
layer/Lbs(Kgs.)
0 42 (12.8) 80 amps 1/9000 (4082)
2000 16 (4.88) 200 amps 2/7280 (3302)
4000 11.9 (3.63) 285 amps 3/6670 (3026)
6000 9.79 (2.98) 350 amps 4/6230 (2826)
8000 8.01 (2.44) 435 amps
9000 6.4 (1.94) 465 amps
Specs for the 9.5ti
Line Pull
layer/Lbs(Kgs.)
0 62(18.9) 47 amps 1/9500(4313)
2000(910) 16.3(4.97) 160 amps 2/8650(3927)
4000(1810) 11.8(3.60) 230 amps 3/7920(3595)
6000(2720) 9.31(2.84) 305 amps 4/7400(3359)
8000(3630) 7.59(2.31) 370 amps 5/6940(3150)
9500(4310) 6.67(2.03) 425 amps
So really what this is saying is if you pull the 9.0rc out you will only be out about 40' and only being able to pull about 6K pounds.
At 40' out with the 9.5ti you still have approx 8k pounds of pulling power.
The 9.0RC really is for really short pulls even with a extension it does not make sense to me.
David
x2 9.5ti all the way
Old Nov 20, 2009 | 08:45 PM
  #24
nangulator's Avatar
I tried a superwinch, it was a POS, I got a smittybilt comp10 (synthetic rope) because I dont use my winch everyday, If I did use a winch everyday, I would get a Warn, Nuff said.
Old Nov 21, 2009 | 03:07 PM
  #25
pjk's Avatar
pjk
Default winches
well, i am rethinking this a little. a winch like the ramsey 8.5se or warn 8000 with synthetic line weighs around 60 lbs (or slightly less). that is pretty close the what i started with thinking about getting a 9.0rc. nobody seems to think a "racing" winch like a 9.0rc should go on a jeep that is not a competitive rock crawler type of rig. the 9.5ti seems like it would be great, however a little pricey with synthetic line. the ramsey 8.5e w synthetic line should be around 750 bucks. now i have to compare some pulling power stats and line speeds to see how much you give up from saving $ and not getting a 9.5ti (or comparable winch).
thanks all for the help
Old Nov 21, 2009 | 03:08 PM
  #26
pjk's Avatar
pjk
i hear you. it looks like warn or ramsey. (no offense to the other manufacturers)
Old Nov 21, 2009 | 04:30 PM
  #27
Woods's Avatar
JeepSWAG
The 8.5e is SSSSLLLLLOOOOOOWWWWW. If you need a synth line, check mine out. Technora line (same as Ramsey sells) at a great price. Couple links:
JeepSWAG winch lines
JeepSWAG synthetic winch rope analisys
Old Nov 21, 2009 | 04:42 PM
  #28
Brian08JK's Avatar
how does an Warn M8000 compare?
Old Nov 21, 2009 | 04:58 PM
  #29
JMP8562's Avatar
thanks again
bottom line : : when you buy a warn winch you bought your last winch!!!!! also if you know your getting synthetic rope then do yourself a favor and get the 9.5si i got the 9.5ti and ended-up getting the rope later (thanks dave Northridge4x4 )
Old Nov 21, 2009 | 05:32 PM
  #30
JK GABY's Avatar
The M-8000 is a little bit faster at 8000 pounds 8.01 F/m (435A)Weight 74Lbs VS. 9.5 TI at 8000 pounds 7.59F/m (370A) Weight 89Lbs. The Duty cycle of the 9.5 TI is better consume less amps = more amp. reserve capacity in the batteries.
Also, with the M-8000 you can mount the solenoids in a remote secure place out of water and moisture.
The cable capacity of the 9.5Ti is 25" more.
My choice is M-8000 tested,his winch has been on the market for a long time
in the warn product line apart of the 8274 its stands alone
