Winch security
Old Jan 1, 2013 | 03:28 PM
randygerm's Avatar
Default Winch security
Installed my new winch in the stock bumper, right side up, over the weekend. Now I understand someone could walk up and disengage the clutch and pull my synthetic line off the winch. Anyone know how to prevent this?
Old Jan 1, 2013 | 03:34 PM
familytime's Avatar
JK Forum Regional Rep
Why not fab some type of lock plate for your clutch lever
Old Jan 1, 2013 | 03:46 PM
Jonathan_JK's Avatar
Here is what I keep in my Jeep for Winch security Glock 22 40 cal and a FiveSeven for long-range if they manage to get further out.
Old Jan 1, 2013 | 03:47 PM
BigSteve's Avatar
This is the most promising that I have found for winch security.
Factor 55 Winch Lock
They are bolts for the winch that are built like wheel security locks. Hope that helps.
Old Jan 1, 2013 | 03:48 PM
zero_traction69's Avatar
Looks like what I keep in my jeep =]
Old Jan 1, 2013 | 03:49 PM
BigSteve's Avatar
Disregard my previous. I thought you were talking about the winch itself. My bad.
Old Jan 1, 2013 | 03:53 PM
Being serious Just take it to your local welding shop have them put some tack welds on the bolts. The winch jackers will have to use a grinder or cutting wheel to get it off and by then if you will hear that and then you can use the other part of my winch security kit
For the line you can Lock the clutch lever with a cable to the bumper. Your going to have to have it made at a shop that has a cable swedger to make it so they can't just slip it off the lever.
Also they would have to have the right size allen wrench on them. Mine is a pain in the Arse to get off since the clearance is almost 0. but I have a winch bumper so its a little bit harder to get in there.
