Winch will not Free Spool, need help
Old Feb 1, 2010 | 11:13 AM
Olean NY Jeeper's Avatar
Default Winch will not Free Spool, need help
I just installed a smittybuilt xrc8 on my jeep. It goes in fine and out fine but when I move it to free spool I cannot get it to move. Am I doing something wrong? This is my first winch so I am a little clueless. Any help would be gret. I tried using the power button to unwind it all the way and then wound it back up but would still not free spool after this.
Old Feb 1, 2010 | 11:49 AM
CA-JK's Avatar
My XRC-8 has the labels on backwards try pulling the line out with the clutch lever in the engaged position.
Old Feb 1, 2010 | 11:59 AM
Would it feed in and out if it was in the free spool position?
Old Feb 1, 2010 | 12:04 PM
john smack's Avatar
yeah my warn will spool in or out when disengaged but not against any force thats all
Old Feb 1, 2010 | 12:08 PM
So I should try pulling on the engaged setting? I guess I will go outside and try that.
Old Feb 1, 2010 | 12:14 PM
CA-JK's Avatar
X2, that is what mine does.
Old Feb 1, 2010 | 12:17 PM
UGOTKERN's Avatar
Several threads on this already.....
known issue.... call Ray at Smittybilt..... he will resolve the issue
Old Feb 1, 2010 | 12:27 PM
CruserBruiser's Avatar
yep it may have came assemble wrong from the factory.. mine was doing the same thing but it got much easier with use and when it warmed up outside. try to feed out some cable then turn the clutch lever to free spool and try pulling on it.
Old Feb 1, 2010 | 12:38 PM
Well I went out and and unwound the hole thing with the remote stopping every once and a while to see if it would free spool and it never did. got the very end and the cable was all tangled up where it connects to the winch. I wound it up trying to get it as evenly and neat as possible and after I wound it up I tried to free spool again. IT WORKED. Thank god, I guess it was just the cable tangled up at the very begining on the first loop of cable. that is a huge relief. I still need to wind it up with tension on the line but that will have to wait for aother day.
