Winter Tires
Actually we do. Here's the question:
My question is I would be using these as my daily driver and the noise does not bother me. Can I use winter tires year round, and how is the wear?
And it has been answered. You can, and millions do, run "all weather" tires all year. They do fine and wear well Michellin makes several. "Snow" tires don't do well year-round because of the rubber compound.
I suggest you do a little more research on studs. I read quite a few studies trying to sort rumor from fact. Modern studs only protrude aprox. 1.7mm from the tread, and show little to no effect on dry pavement performance. They also have next to no impact on road surface wear -- the main reason studs are often discouraged by government agencies. Note that older stud designs protruded quite a bit more, and many of the older studies (the basis for many current 'opinions') were based on these longer studs. The only downside I could find on modern studs (aside from the noise, of course), is they're only super effective within a specific temperature range. They're *very* effective in that range though! :-)
js.
js.
js.
So no, no one properly answered it :P
js.
js.
js.
. Regardless, people who have done side-by-side comparisons say "They don't do as well on dry roads".Anyway, using simple physics it's not hard to deduce that:
a) with studs, less rubber touches the road
b) rubber offers a more desireable road feel than studs.
Not saying they aren't worth it, and I know that studding tires almost always helps a TON on ice. I wouldn't doubt that the benefits of the studs far far outweigh the disadvantages, if the disadvantages are even noticable
These are the tires I am thinking of getting. First tire at the top of the link
http://www.remingtontire.us/Pages%20II/mudsnow.html
