Which wire is the low beam wire
Old Aug 11, 2007 | 03:09 PM
cremeansb's Avatar
Default Which wire is the low beam wire
I'm hooking up some Hella 500's and need them to come on with the low beams only. Which one of the 3 wires going to the headlight is the low-beam one, and where is the easiest place to tap into it at?
Thanks in advance.
Old Aug 11, 2007 | 06:02 PM
mcnaught6's Avatar
if you hold the headlight connector in your hand, with the red locking tab facing upward, the low beam is the one on the right. i don't remember which color it is right off hand.
Old Aug 12, 2007 | 04:36 AM
cremeansb's Avatar
Yep that is the one. Thanks for the help.
Old Aug 12, 2007 | 12:01 PM
cremeansb's Avatar
Here is a pic in case anyone else needs to wire in aux lights. Mine were hooked into the driver's side headlamp harness.
The low beam lead is the white with blue stripe.
Old Oct 20, 2007 | 02:35 PM
bubbabeer's Avatar
Which is the high beam? and whats the 3rd wire?
Old Oct 20, 2007 | 06:29 PM
toycop's Avatar
White with green stripe is high beam. I believe the other is a ground.
