Wobble??
Old Apr 19, 2014 | 07:09 PM
Officerg's Avatar
Default Wobble??
Ok so I do not have the death wobble problem. But I do have a slight wobble when I'm going about 65 MPH and hit some bumps. I have a 3.5" lift and I replaced trac bar bushings also have put some RK adjustable control arms on. My front tires are warn out but I recently got them balanced. So I need some help. I'm about to replace tires, are the tires the problem?
Old Apr 19, 2014 | 07:25 PM
skates04's Avatar
I had the same issue and it was a drag link ball joint. Have some one turn the steering wheel slowly while you grab the tie rod/drag link on each end if you feel it clicking/jumping that's the one. There's a good video out there some where probably under death wobble if you do some searching.
Old Apr 19, 2014 | 07:29 PM
skates04's Avatar
Here are the videos there is a second part... Follow this and you will fix it.
http://m.youtube.com/watch?v=9uQwlmlhiF4
Old Apr 21, 2014 | 05:32 PM
Officerg's Avatar
Thank you buddy
