Wobble at 45 mph
So I have a wobble at 40-45 mph. I've had it for the last two weeks since my last trail run. It's not the tires being unbalance because I just switched today from 35s to 37s and it's more noticeable. It's definetly not bad enough to be death wobble.
Any guesses? I checked all the bolts to the steering underneath and nothing was loose or worn.. Thanks Sent from my iPhone using JK-Forum |
Originally Posted by JKBANDIT55
(Post 3632275)
Originally Posted by JK yeti
(Post 3632313)
My first suggestion would be to check the ball joints, that's a very common cause to shimmy's and small wobbles, I just upgraded to synergy ball joints and my shimmy at around 50 mph went away, by the sound of it I'm assuming you already checked tie rod ends and dragline ends? Sent from my iPhone using JK-Forum |
You might have new tires but are they the same rims. I would swap the fronts to the back to rule out a rim being the culprit. If it only happens at a certain speed its usually a tire /rim problem.
Originally Posted by Biggy
(Post 3632383)
Had the same problem recently and my tie rod ends were shot. Fixed and problem solved
I have the exact same issue, after reading this article I think my problem is a bent driveshaft, what do you guys think?
http://www.off-road.com/jeep/tech/re...aft-53546.html |
(Post 3632372)
Hmmm haven't checked those yet. How long before they usually go out? It's a 2012 with 16k miles Sent from my iPhone using JK-Forum |
I had same issue, the bushings on the upper control arms were shot. I replaced them and problem solved
I cant figure it out. Im starting to think ball joints but still not sure. Gonna take it to a buddies shop to see if he can help.
Thanks guys |
