Wobble at 55 MPH
Old Nov 26, 2012 | 03:53 AM
JK yeti's Avatar
So just recenly i put a new rough country steering stabilizer on my jeep. Love the feel of it and it coverd up my death wobble for now. But the day after i put it on the steering wheel and whole jeep begans to wobble at 55 mph? Doesnt do it a 50 mph or 60 mph... Checked for loose bolts dont know what else to do... Had the tires balanced about a month ago. Any ideas what it could be?
Old Nov 26, 2012 | 03:58 AM
BosoxJK's Avatar
Originally Posted by Jeepkid850
So just recenly i put a new rough country steering stabilizer on my jeep. Love the feel of it and it cured my death wobble. But the day after i put it on the steering wheel and whole jeep begans to wobble at 55 mph? Doesnt do it a 50 mph or 60 mph... Checked for loose bolts dont know what else to do... Had the tires balanced about a month ago. Any ideas what it could be?
I had a wobble after my 2.5 lift was put on everytime I hit bumps in the road. I loosened all the control arm bolts and track bars the day after I had already torqued them and retorqued them and it solved my issue. Just check the bushings too
Old Nov 26, 2012 | 04:51 AM
JK yeti's Avatar
Already retorqued everything under there. Any other ideas? Toe? Caster? Alignment?
Old Nov 26, 2012 | 04:55 AM
Robar's Avatar
Speed related wobble is very often due to tires being out of balance. A steering stabilizer does not cure anything like death wobble. It only covers it up. The cause is still there.
Old Nov 26, 2012 | 05:04 AM
JK yeti's Avatar
Alright well i'll take it in to discount tire this week. And i know about the steering stabilizer not "curing" death wobble only cover up the real problem. Im just hoping it covers it up a little longer untill i can save up a little cash.
Old Nov 26, 2012 | 05:11 AM
Robar's Avatar
OK, I must have misunderstood when you said it cured your death wobble.
Old Nov 26, 2012 | 05:13 AM
JK yeti's Avatar
Thats ok shouldn't have said cured.. Would ball joints have anything to do with the wobble?
Old Nov 26, 2012 | 05:25 AM
Robar's Avatar
Yes. Worn ball joints can be a cause of death wobble.
This link has some good info:
[h=1]DEATH WOBBLE : What it is, What it isn't and What You Can Do to Fix it[/h]
Old Nov 26, 2012 | 05:53 AM
JK yeti's Avatar
Good info! Thanks!
Old Nov 26, 2012 | 09:47 AM
Freewill's Avatar
Every wobble starts with something that rotates and is out-of-round or out-of-balance or both.
Once the wobble starts:
  • loose bolts,
  • bad bushings,
  • worn ball joints,
  • worn tie rod ends,
  • loose shock mounts,
  • wheels bearings,
  • a worn steering box,
  • loose or shot steering damper
  • and pretty much anything else that moves
can allow the wobble to keep going and even amplify until you pull over and start scratching your head
