Woods Tailgate Strut and Tuffy Security Deck
Old Mar 9, 2010 | 08:32 AM
Sharkey's Avatar
Default Woods Tailgate Strut and Tuffy Security Deck
Does anyone have both of these products installed? I'm trying to figure out if these products are compatible. Thanks!
Old Mar 13, 2010 | 02:25 AM
svalvasori's Avatar
I'm hoping so, I put in the deck last night and will try to install the strut this weekend - for sure it will not install as per instructions. I'll need to figure out if it's better to cutout the deck or install the strut on the deck side.
If anyone has any suggestions before I choose the wrong option, I'm all ears.
Old Mar 13, 2010 | 05:07 AM
codysanders's Avatar
i can't find the write up about it but i remember that the guy ended up cutting the deck to make it work.
Old Mar 13, 2010 | 05:40 AM
Sharkey's Avatar
Make sure you post some pictures if you come up with something. From pictures I have looked at, it appears that the deck lid and the strut sit at about the same height which is a problem. I was hoping the strut would tuck under the deck lid.
Old Mar 13, 2010 | 03:22 PM
njbeachrat's Avatar
i have both installed...
before the tuffy security deck i had the woods strut installed to the body as per instructions...
got the tuffy deck and installed the strut to the passenger side wall of the security deck...its been on since sept. and works perfectly fine. i was only able to use two of the three holes on the strut bracket to mount to the security deck wall. the strut sits below the top lid and doesnt hit or interfer when opening and closing the rear door.
Old Mar 13, 2010 | 03:24 PM
njbeachrat's Avatar
when installing the strut you are going to have to mount the passenger side wall measure and mark (twice) then remove and drill...i then installed the two front most screws with bolts facing into the enclosure and re installed the wall...once the enclosure was inplace i reconnected the strut...
no visible warping of the enclosure and everything is ok on the door...
Old Mar 13, 2010 | 05:31 PM
Sharkey's Avatar
that is great to hear. Thanks for posting your response! Any chance you could post a couple of pics?
Old Mar 13, 2010 | 05:44 PM
njbeachrat's Avatar
its a monsoon outside...i'll post up some pictures tomorrow when i can get to a garage
Old Mar 13, 2010 | 06:19 PM
Sharkey's Avatar
Lol. No worries. I appreciate you even taking the time to post in the first place.
Old Mar 14, 2010 | 02:36 PM
svalvasori's Avatar
Did it over the weekend, you have to cut the deck but all works out great! I love both of these products.
