would it be possible to run 37's?
Right now I have the TF 2.5 coil and shock lift, I do mostly highway driving and don't wheel really hard but I do enjoy going on some easy/moderate trails. So what I'm asking is that would it be possible to run 37's just by upgrading to a 3 inch coil instead of the 2.5's that are on there already and throwing on a 1" body lift thus yielding an approx lift of 4". I know that there would also be some cutting and probably adding flat fenders later on. To strengthen up the D30 I would also get "C" gussets welded in. I just don't want to upgrade to 35's and be pissed that I didn't go up to 37's when I probably could have. Is this possible or should I just stick with my original plan of going to 35's? forgot to mention that I will be regearing to 5.13's with the larger tires.
thanks in advance for your answers and opinions on this question.
37s on a 3" with one body would be no problem at all for a daily driver and minimum wheeling
you will have to cutt the rear pinch seem on the front of the rear fender well on the tub of the jeep.
also u will have to extend your bumper stops to reduce rubbing when off road and .... hd steering stabilzer and you should be good to go
goodluck!
goodluck!
TF 3" + 1"BL
or
TF 3" + chopped/flat fenders
