Would this tire carrier actually work???
Old Jan 28, 2010 | 01:59 PM
_J__C_'s Avatar
Originally Posted by Bazetthound
I thought about the MBRP kit, but I don't like the little clamps they use instead of nuts. I think the clamps wouldn't be as strong.
... That's a good point. I looked at again and I think you're right. When it comes in I'll look at everything and see if I can get some nuts/washers on it. I'm not sure if there is enough room to get a hand and a wrench back there, but you never know.
Old Jan 28, 2010 | 09:50 PM
Bazetthound's Avatar
What about a steel plate on the outside the size of the raised square portion of the tailgate where the factory carrier mounts? Wouldn't that distribute the weight a bit more? It would certainly be easier to do.
Old Jan 29, 2010 | 06:14 AM
_J__C_'s Avatar
A thin plate would probably work quite well. Would you want to still use the factory nuts that are tac-welded on? Is there enough room to get your hand through the inside vent on the door to replace them with a nut and larger washers?
