XHD tire carrier
has anyone modded or found something to retrofit jerry can holders to the XHD tire carrier.
Even better would be the thing id seen a long time ago that carries 2 jerry cans, and has a top rack over the rear wheel.
Take a look at rock hards jerry can mounts. I have the XHD and was thinking of doing the same thing & I saw a set of rock hards at the vendor show in Moab. The tire swing set up is pretty close to the XHD and from what I could tell the only thing you might have to do is change the angle of the mount just a bit. The XHD side bars are angled at around 50 degrees and rock hards are around 45.
